Stripping the tint
Started by Sweet Lover, December 28, 2006, 06:41:56 AM
Sweet Lover
hi all -
i need to get the tint off the windows of the car i purchased. its a 1990 model so its got that 80s violet tint all around it. yeah im a fan of the 80s and  i can listen to duran duran driving all day but the 80's tint has to go! i want clear windows!
yesteday i spent half a day working on the front windows, driver and passenger. i still have 5 windows to work on. i used windex and household degreaser to loosen the adhesive but that did not help very much. yeah the tint seemed like it was put on using super glue. let me know if you have something in mind. but dont tell me to use gasoline and torch the tint..i have a crazy cousin telling me that.
also, the rear window is going to be a problem because it has the defogging lines so i got to be very careful doing it.
98nassin
sir use a blade, yung pang shave, rubie gilet, tapos strip a portion then hila dahan dahan, then pag tangal na, use joy ultra with anti-back, mixed with water, spray small about on the area and again use the blade to shave the sticky part off...thanks :)
Sweet Lover
thats not a bad idea! yeah i did use a blade the other day. i will try that over the weekend if i have spare time. thank you.
ment
maybe you would like the idea of installing "clear" tints?  it still offer heat rejections and UV protection sa interior. unlike kung totally walang tint.
if interested ka then have the tint removed by the installer nalang then  :)
98nassin
sir boy bawang taga saan po ba kyo? kung malapit lang po kyo sa las piñas, tulungan ko po kong tangalin yan..HEHEHE...masarap mag DIY ng car e...:) ;D
Sweet Lover
#5
Quote from: 98nassin on December 30, 2006, 10:11:41 PM
hey i appreciate your offer to help but i am far from your location. i still have not stipped the rest of it. i have been too lazy sleeping and playing all week plus this week is new years week so im all booked.  :)
hey i checked out your sentra...where is the finished producT? or is it still in progress?
Sweet Lover
Quote from: ment on December 30, 2006, 04:41:07 PM
wow theres clear tints? thats pretty awsome! i have not heard of it. ill research on that. thanks.
98nassin
meron pong "all about tint" thread po dito, dinidiscuss yung mga color and benefits ng tints, you may check it out.
sir boy bawang, yung car ko, okay na po yung paint, yung front widows striped ko poyung tint.
pero focused po muna ako sa engine puto DIY kaya matagal at wala pang budget e, student palang po ako, so sobrang tipid sa baon, hehehehe...
pati di ko muna papatint kase im planning na patitan yung doors sa automatic po lahat, nag hahanap pa ako ng surplus nang doors na automatic...
matagal pa po ito...heheh
thanks
ment
Quote from: boy bawang on December 31, 2006, 04:28:46 PM
punta ka sa banawe may mga nagkakabit ng clear tint doon. would cost maybe 2.5 to 3K
lomo13
hi sir, hope this helps..
removed my tint some time ago.
peeled off the tint slowly para buo siya matanggal,
tapos was able to remove the adhesive residue using shampoo, eureka! moment nga EH. used pantene BTW.
small amount lang sa basahan tapos water para bumula.
work on the adhesive na lang by rubbing the basahan against the window.
west traveling east
popoyn2r
Quote from: Sweet Lover Driver on December 28, 2006, 06:41:56 AM
hi all -
sir blade cutter and shampoo kailangan mo sir sunkitin mo ng blade cutter yun dulo ng tint tapos hilain mo pag may natira sprayan mo ng shampoo para tapos kutkutin mo ng blade cutter pag dating sa rear glass pag may def. horizontal ang pag hila wag vertical minsan kasi sumasama yun tin pag pa vertical ang hila tyagain mo nlang ng kamay wag kna gumamit ng blade cutter dito
N2RCarwash and Detailing
181 J.P. Rizal St. proj. 4 Q.C.
and
P. Tuazon near Labor Hospital and Emerald Square
centZ_
sa akin gnawa ko nilagyan ko ng small amount of brake fluid sa basahan tpos in-aply ko sa salamin, ayon natangal naman kusa
CrackedRearView
i have the same question. Need to remove my old tints na kulay talong na!
I was in Banawe last week and asked the "freelancers" how much they charge for tint removal. Sabi P350 daw! Is that a good price?
Tempted ako to DIY it pero baka di ako maging successful...
bowkia
Sir, 350 is kinda high, It should be only around 150-250 tops. evanglista or banawe. thankyou.
GeorgeTuc
Ako, i just sprayed it with warm water and shampoo solution (hehe, trying to complicate) and used a thin knife to take it off. Ang sarap kaya  magtanggal nyan!
