Oil Question
Started by RaV4.2, April 19, 2007, 10:42:57 AM
RaV4.2
WhaT is the oil capacity of the RAV4.2 1AZFE ENGINE? TIA!!!
We import OEM radiators, condensers, evaporators, aux fan, steering rack and pinion etc...
For inquiries pls call 09175262406 09228501132
Victorb
kindly check your owners manual
most likely around 4 liters
4 liters give or take a little.
archico01
what about a 96, nissan sentra series 3? Thanks
OT: speedyfix, you've been a really great help on this forum!!! More power!
nonie
What is the best Motor Oil for my Hyundai Santa Fe Crdi VGT?
Hyundai Alabang is always using Shell Helix  Super Diesel(yellow container). I think it is for non crdi diesel engine only. Meron bang available oil for crdi engine? ???
h2
pag engine flush ano ok? cheap engine oil or yung sa petron ata or caltex na oil base?
Victorb
based on experience, only use oil based engine oil flush
caltex is very good
just flush your oil once a year
and add duralube!
h2
Quote from: EudmAccord on May 16, 2007, 10:28:20 PM
caltex is very good
and add duralube!
thanks for the reply.
yung engine clean ng motul oil base? pag i compare sa caltex hindi nagkakalayo? sino pala mas ok sa dalawa?
duralube? ok ba talaga yan?
caltex is very good
and add duralube!
No do not add any oil nor engine additive/treatment!
http://www.carbibles.com/additives.html
h2
#9
Sir Conan
How about yung caltex oil based flush, ok ba?
yung motul engine clean oil base din? pag compare silang dalawa hindi naman nagkakalayo?
hindi ba advisable pag nasanay daw yung car na mineral oil tapos mga 80 thou kilometers na tapos bigla mag synthentic?
Thanks
Quote from: h2 on May 17, 2007, 12:13:15 AM
Sir Conan
Thanks
It really doesn't matter when you switch to synthetic oil or what you used to use in the past. It doesn't need to be flushed either unless you've neglected to regularly change your oil or you bought the car from someone else who neglected it.
Quote from: nonie on May 16, 2007, 08:54:28 PM
Hyundai carries Shell products. For CRDi motors a rating of ACEA B4 should be present. This is found on CRDi Specific oils.
Mobil and Motul have oil for CRDI engines. Mobil has Delvac 1 while Motul has Specific CRDI.
hth!  :)
tad
Try mo mobil delvac MX 15w-40. ok ang performance... Ginagamit yan for crdi engine.
tad
Tanung ko lang kung ilang kilometers dapat palitan yung gear oil and ATF?
