Right octane rating for jdm h22 engine
Started by h22prelude, July 22, 2007, 05:01:30 PM
h22prelude
ano ba ang dapat kong gamitin na octane rating ng gas para sa JDM h22a engine ko
the compression rating is 10.6:1
thanks..
H22a Prelude 4th Gen
200 hp stock!
lantraluvr
If I am not mistaken, high performance JDM engines are meant to run with 100RON gasoline. We don't have that here. Blaze goes only to 96.
98 Hyundai Elantra 2.0 Beta
06 Hyundai Getz 1.5 CRDi
http://hyundaiclubph.proboards25.com
http://www.lantraluvr.com
h22prelude
so mag BLAZE nalang ako?
stock po ang h22 ko..
200 hp stock!
Accord GTR
Nothing lower than Blaze which is the minimum already.  If you happen to get bad gas or your fuel system is not functioning properly, you may hurt your engine.  My EK9 is about that compresseion ratio.  When we checked it in the dyno when we 1st got it, it was running lean at the top and rich below Vtec.  That's how JDM high perf engines are usually tuned cuz they are tuned for Japan.
You need to get a programable box and tune your engine for local conditions.  Otherwise, you may damage your engine.
There is no dishonor in losing the race. There is
h22prelude
Quote from: Accord GTR on July 25, 2007, 07:00:29 PM
ang comp box na ginamit ko is yung kasama sa package ng engine -h22 (swap lang ang h22 ko)..
wala pa kasi akong pera pambili ng comp box.. estudyante pa kasi..
ano po best kong gawin?
mag Blaze nalang ako?
i nid help talaga..
200 hp stock!
jdrex
Go to petron greenhills, edsa corner connecticut. ( the service area not the pumps ), they have on hand stock of high octane motor fuel in drums. You can fill up there. these are sold at  47 pesos per liter as of two days ago and are 102 octane ( RON ) .
Coffee
Quote from: jdrex on July 28, 2007, 03:52:08 PM
:o whoa! Valuable info. Many thanks.  ;D ;D ;D
Born to evolve and accelerate. The thrill of going through hell and getting through it.
Accord GTR
Blaze should be fine.  I always try to fill up nga at that EDSA Connecticut gas station cuz it's reliable.
Just try to listen for knock or ping (a metallic knocking or clicking sound in the engine in low rpm's or backfire in high rpm's) when accelarating hard or going uphill.  If you detect any, do not race the engine!  You need to set the advance timing lower or use higher octane gas.
I think the H22A is set at 16 degrees advance.  You can have it set to a lower advance by a mechanic is you are using bad gas.  Check you spark plugs periodically...they should be brown.  If they are very light color, almost white, or show damage, you are getting lean mixtures and/or detonation.
if you're not hearing knock using blaze then no need to do anything else.
Dondie
Great info sir. Thanks, :)
JDMselect - High Quality Parts and Service
144 Mindanao Ave. Q.C.
86 Gil Fern
AUCH
Quote from: h22prelude on July 22, 2007, 05:01:30 PM
thanks..
i strongly suggest using the highest octane pump fuel that you can find
as far as i know, jdm h22vtecs are fed with 91-93octanes in japan as our h22vtecs in nz use mostly 91 octane without having any knock problem at all, but those guys are just being cheap though...  hehe...  peace man (if there are any nzhonda guys out here...  sup man)
