help naman po...
Started by Mardy-GTI, December 19, 2007, 03:23:12 PM
Mardy-GTI
help naman po kung ano po maganda gamitin na oil sa engine 4G63 DOHC? for every day use lang po, pero palage rin hataw. thank'z po in advance sa mga mag reply
Mo Cool
Quote from: mardy on December 19, 2007, 03:23:12 PM
MOTUL H-TECH 100 10W40 fully Synth is ok na Php 430/Lit
MOTUL FOREVER
Mardy-GTI
ok... thank'z poH! gano naman po katagal bago ulit mag change oil? at ilan liter po ang laman ng engine ko? wala po kase ko lam sa 4wheels.. :newbie:
Mardy-GTI
kailangan ko pa po ba gamitan ng engine plus kung mag change oil ako, hindi ko po natanong dun sa 1st owner kung kailan hule ng change oil... dati po gamit na oil ay  MOBIL Super XHP 20w-50, mag 1  month pa lang po sa akin ung galant ko model 92,gano po ba  katagal life ng engine ko kung MOBIL Super XHP 20w-50 ang gamitin ko o mas makakabuti po kung MOTUL H-tech 100 10w-40 ang gamitin ko??? ilan liter po ba ang laman ng engine ko. thank'z
stayTUNED
Quote from: mardy on December 19, 2007, 11:19:03 PM
don't rely on the seller, kung natanong mo siya or hindi regarding sa last niya change oil it doesn't matter. basta bili ka 2nd hand car change oil is a must. not unless kung tipid ka or marunong kana kumilatis ng langis kung ok pa. not sure kung ilang litters yan pero ok kna sa motul h-tech 100.
AUCH
i wouild recomment the castrol gtx protec if you can find it in pinas.  the rating is 15W/40 or if you are alright with versions that are a little more expensive, then get the magnatec in which the rating is 10W40.  both these have not failed in my experience yet and some of the guys that i know that has the E39a (the real) VR4 that rates 400hp atw are using the same oil with often blats have good healthy 4G63's
yeah 2 of my friends are using the 10w40 one for the mr2 tt and the vr4 tt
Mo Cool
Better if you do engine clean MOTUL recomend the use of engine clean specially when your car has an high odo na. and also syempre pag ibang oil ang gamit mo dati. more or less nasa 5lits yan
MOTUL FOREVER
Mardy-GTI
San po ba makakabili ng motul? nagtanong po kase ko dito sa lugar namen sa laguna, wala ako makita.  san po ako makakabili at anong address? thank'z
if it's an old engine and it has been using a 20w50 weight oil since before you might find na magkakaleaks yan by switching to a thinner oil. be prepared and check regularly nalang imo.
Mardy-GTI
ganon po ba... model 92 po kase sya, sbi nung nabilhan ko mobil Super XHP 20W-50 ang gamit nya...  :dontknow: e di kung magka leak po cya mas lalake ang gasto ko...
primo
Try using ENOC Protec Premium 20w/50, imported sya, baka mayroon sa Laguna.  I tried it and it performed well for my car.
when in doubt just use the same one that was used by the previous owner.
