caliper painting
Started by Mardy-GTI, February 05, 2008, 07:47:50 PM
Mardy-GTI
mga bos! ano po ba maganda gamitin na pintura sa caliper at rotor? pwede napo ba ang acrylic o nid pa hi-temp ang gamitin? thank'z
the caliper gets really hot. i suggest you use high temp paint.
stayTUNED
its all up to you. hi temp limited lang colors pagpilian mo. parehas din sila bakbak katagalan.
Mardy-GTI
LotusUSA
Quote from: mardy on February 05, 2008, 07:47:50 PM
Dupli-color caliper paint.  Make sure you clean/degrease your caliper before you paint it.
Mardy-GTI
zinggoy
are you asking for DIY?
Zinggoy's Paintworx
Has moved into a new home...
Fastrack, Capt Javier st., Brgy. San Roque, Pasig City
09186102994
Offers premier
Mardy-GTI
yes sir, diy lang po... thank'z
zinggoy
Quote from: Mardy-GTI on February 22, 2008, 11:09:23 PM
for d.i.y. your best option is a high temp paint in aerosol cans. however, as posted by "-jason-" very limited color choices. you may try acrylic paints or better yet go to highlang trading along shaw pasig side. they can mix any color of your choice and put in aerosol cans. they key there is prepping the calipers and rotors. make sure its clean and grease-free, sand it down by a 600 or 800 grit sand paper then paint away  ;D
f.y.i what we use in the shop is dupont urethane paint. we just use a special activator to promote beter adhesion. with this, we have a lot of color choices  ;)
Zinggoy's Paintworx
09186102994
Offers premier
BlueVic_8354
anu naman mga fafy magandang pantanggal ng mga brake dust sa painted caliper?
My EG-8
[img width=250 heig
Quote from: BlueVic_8354 on March 12, 2008, 08:39:53 PM
meron nabibiling mga brake cleaner...spray lang and you can either wipe it or just let it evaporate.
bigdaddysmooth
Quote from: LotusUSA on February 12, 2008, 05:09:42 PM
sir san pwede mabili yung dupli-color caliper paint...TIA
"Smile is the best camouflage of all"
Quote from: bigdaddysmooth on October 06, 2008, 06:39:49 AM
I think this is only available in the US.
Here's a link to the product page, looks promising and its just a brush on product. You can really do a DIY.
http://www.duplicolor.com/products/caliper.html
popoyn2r
Quote from: Mardy-GTI on February 05, 2008, 07:47:50 PM
hi temp sir para d mabilis mabakbak
N2RCarwash and Detailing
181 J.P. Rizal St. proj. 4 Q.C.
and
P. Tuazon near Labor Hospital and Emerald Square
partsRus
since DIY is it possible na high temp first coat
followed by preferred color
also may high temp ba na clear coat?
if so ... possible din ba na ipang top coat yun sa preferred regular paint
thought of doing the calipers on my ride din e
