fenton vs v12 amplifier
Started by miko fan, September 22, 2008, 12:28:59 PM
miko fan
mga kapwa ai patulong nmn
im planning 2 buy an amp
newbie sa setup
alin mas recommend nio?
fenton f41000 4 channel amp 125rms by 4
or
v12 Mrv-1507/ mrv-710
alin sa mga yan boss? ok ba ung fenton? salamat sa mga magrrply. need help lng tlga para matapos n setup q.. :occasion14:
Quote from: miko fan on September 22, 2008, 12:28:59 PM
newbie sa setup
or
Both are almost the same. Although mas maraming nagsasabi na mas malinis daw sound ng Fenton than the V12.
miko fan
Quote from: Brent on September 22, 2008, 03:43:07 PM
thank you sir brent.. may bass boost pa ang fenton na amplifier?and mabilis ba xa maginit like the v12 ones?
thank you!
miko fan
totoo bs ns 125x4 lng ang rms na kaya nung f41000?
so pwede na xa para idrive ung 2 seps 2 coax and a sub with 300rms? tanong lng sa mga gurus and kapwa Ai
mabilis ba maginit ung fenton na f41000?
thank you pipz!
Sir Brent salamat sa reply mo..
  :wav:
rein
based from experience, yung mga china amps po sir mabilis talaga mag init and mabilis abutin yung clipping limits nila :) pero proper placing ng amp would really help, like sa ilalim ng front seats or anywhere else but the trunk. :)
not sure about the true rms rating of the amp pero more or less nasa ganyang range na po yun :)
autofreak03
lowrider888
fenton for me...but if you can stretch your budget a little bit more..dami amps na okey...
pwede din mga used branded amps...just make sure na good condition lang...
imho
