low viscosity synthetic oil causes leaks???
Started by joseph0119, October 19, 2008, 08:44:27 PM
joseph0119
is it true that low viscosity synthetic oils can cause leaks in older model vehicles?
ive been experiencing oil leaks ever since i switched to RP 10w40... ive replaced all oil seals, gaskets and o rings but the leaks still persist... my mechanic says it must be the oil... ??? ??? ???
should i switch back to mineral? if so, what viscosity and what brand is good? or would it be good to go for thicker synthetic?
2000 model car, gas,103k mileage, matic....
Thanks!
avoid hangovers... stay drunk
niky
Depends on the engine and engine wear. At 103k kms, I suppose you're engine's pretty worn in... I'd suggest going to a "high-mileage" oil... there are 20w50s available in synthetic I believe... if thicker oil doesn't cure it, then it's something with the engine.
What car is this?
joseph0119
redpitz
#3
hey joseph0119, hi!
i suggest u add an oil thickener first to know if your problem will be solve than dumping your oil and buying another batch of new oil... medyo mahal din yan. pero bago na yung mga gasket and seal kamo eh... baka kaya kulang lang sa tightening torque or hindi kaya nagseal cya mabuti? petron has an oil saver in a small can, try mo muna un... saan ba cya nagleleak? side gasket ba between the head and block?henry
ConanĀ®
Quote from: joseph0119 on October 19, 2008, 08:44:27 PM
Thanks!
What area is it leaking?
joseph0119
im not sure dun sa terminologies pero the leaks used to come from the O Ring in the distributor... i had it remedied but after a few weeks, leaks nanaman from some other area i have yet to trace... i might try switching to a thicker oil nalang... hope you could recommend a good oil replacement given my predicament... thanks!
redpitz
#6
dalhin mo nalang kay speedyfix ung car mo... para makita talaga ung leaking problem mo, i think it's not the oil that is the problem, ksi even if you fill heavier weight oil, at normal operating temp, the difference of a 40 wieght oil and 50 weight oil inside the engine is only about 4 to 5cst,unless group V oil lagay mo that will swell any seal in the engine.  i doubt that the oil is the problem kasi you only bump to a next heavier oil  only if you are consuming oil without any leaks maybe by 1 quart every 2000kms, which means oil is getting pass the compression ring and getting burn through combustion process. suggestion lang.
joseph0119
I already had it checked at speedyfix before.... they recommended that i have the o ring replaced... i did that and the leaks stopped for a few weeks... then bumalik nanaman, this time di ko na matrace yung source ng leak. anyways, i guess you're right... better have it checked nalang ulit muna. thanks for the inputs!  :thumbsup:
redpitz
hey, no problem... we are here all to help each other out. :occasion14:
henry ;D
2fastjarum
Quote from: joseph0119 on October 19, 2008, 09:12:09 PM
its a 2000 esteem suzuki wagon... tnx
wow sir you got 103km sa 2000 esteem, nacheck nyo na po ba ang timing belt nyan??baka po bigla na lang kayo itirik nyan..   baka po naman po pang overhaul na po ang makina nyan, im pretty sure hindi na naglalapat mga piston nyan, kaya siguro may leak... imho , better po ipa engine wash at duon po kayo magstart magdiagnose kung saan galing ang leak baka po sa oil filter lang, o baka top overhaul lang po hindi natin alam, engine wash is the best... tapos ipa lift nyo po...hth... peace
oil is oil. same viscosity oils will have the same viscosity regardless if they are synthetic or mineral under the same conditions/temps. if you are using a thicker oil to stop leaks then the engine is not running at the optimum. sayang din.
at that milage, it is pretty common for rubber to wear out. if it leaks, replace the seal and hindi na sya dapat bumalik sa same spot for another 100k. if it does may problem sa kabit. if palipat lipat also check/replace the pcv. it might be barado na kaya the engine is popping the seals out.
Qkid
Quote from: joseph0119 on October 20, 2008, 09:41:49 AM
its pretty normal for an aged engine to leak oil. the viscocity has nothong to do with the leaks. best bet is to bring it to a competent mechanic and have your so a check on the oil seals. also dont buy the cheap seals as they  not last as long they should.hth
bong
if you dont know where to look, you wont see what your looking for.... so get somebody who knows where to look... :violent1:
'78 lancer
i seat the valve cover gasket properly and tried to evenly tighten all bolts. No leaks. :thumbsup:
Actually i used some silicon sealant. :)
10W30
