overhaul of radiator
Started by sherwin08, November 04, 2008, 12:01:25 PM
sherwin08
Mga gurus.. magkano kaya estimated price for overhaul ng radiator?
Depends on the kind you have.  Normally I'd buy surplus than overhaul.  Surplus only 1500-2000 depending and much better than local overhaul.
kaskasero
i've tried overhaul and i've tried surplus
im happier with my surplus radiator. overhaul only lasted like around a year or something
sherwin08
tnx po sa info.. San kaya ako mkakabili ng surplus na rad? My car is 96cvc..
this is in the wrong forum... please move it.
sherwin08
Quote from: speedyfix on November 05, 2008, 01:11:39 PM
sir see u on sat.. tnx sa quote earlier..
vmobile88
bakit kailangan overhaul ang radiator? in the first place.
dealer of replica watches, and other business http://50store.multiply.com
sherwin08
Quote from: vmobile88 on November 06, 2008, 11:13:31 AM
sir nag-overheat yung oto wen i used it last sat.. nagflush nko palit hoses, coolant at thermoswitch.. pero gnun pa rin.. anyway ddalhin ko na cya dis wikends sa speedyfix..
kaskasero
Quote from: sherwin08 on November 05, 2008, 11:35:32 AM
evangelista, banawe... the usual
Q: how do you overhaul a radiator anyway?
Qkid
yup. jsut get a surplus rad. usually it comes with the cooling fan so you can save it for later on. If you  rather have it overhauled, just bring it to a reputable establishment so you can bring it back just in case. better also to use distilled h2o so no minerals will get traped in the radiator. :)
doods
sir suggest ko instead of overhauling why not just invest on a bnew radiator? that's what i did and replaced mine with evercool. The reason pala na nagpalit na ko since di na kinaya ng overhaul :)
