planning to costum a vintage car help pls.
Started by char012, October 17, 2009, 03:21:05 AM
char012
hi po, 1st time ko po mag post.
:newbie:
just bought a vitage car Toyota Corolla TE72 liftback pero muka pareng bulok plano ko po sana  i custom
like this:
ganitong ganito ren yung mags na gusto ko chaka kulay
may side at front skirts  na ren siya ng binili ko. chaka lowered na ren.
paint job nlng at tires and mags. magkano po ba ang budget for:
paintjob yellow semigloss?
mags and tires katulad sa pic?
salamat po sa help! :thumbsup:
if i may add
magkano ren po ba mag pa ren mag paayos ng:
wiper
signal light
headlight :violent1:
horn
aircon
window matic
if ever mhal xa papa kilo ko nlng haha  :crybaby2: :dontknow:
ipambibile ko nlng ng bagong sasakyan yung pang custom ko.
crystalyk_oo
pre ako meron pina pa paint job na liftback...depende din kung change color. dun ka mapapamahal at dipende sa tama nan sasakyan kung meron man..kung papakilo muh paki kontact na lan ako. baka may parts na magamit ko galing sa auto muh,,,salamat
A new paint job (strip to metal) including latero will cost you a minimum of 50k. expect mo na mas mataas pa as the work progresses.
please remove the side skirts bec. it's not period correct. you can retain the front chin pero dapat kuwadrado siya at di bilugan. para period correct rin.
mags and tires setup like the one in the pic will depend on what brand ng mags kukunin mo. expect a minimum of 15k for the mags only, then around 10k for the tires (mukha kasi siyang 15's).
for all your electrical problems, general rewiring will be your long term solution. around 15k tops pero make sure na magaling iyong electrician na gagawa. i convert mo lahat sa relays para mas tumagal ang buhay ng wiring.
if you're junking the car PM mo ako and send me pics.
