Lancer '97 ECU
Started by mykdelarosa, October 21, 2009, 11:07:18 PM
mykdelarosa
how can i remove the car's ecu (mitsu lancer 97) and where is it located? my car was submerged in water, 2 feet above the car's roof to be precise... :-[...i have not given it the proper maintenance after the flood, though the car is running now. I just blow dried  every electrical piece I can find in the car.
The Jordan
Underneath the dashboard. passenger side it's mounted to the upper kickplate area.
HTH
The real question is.. when you turn your car on, does it return the favor?
mykdelarosa
Thank you for your advice reg ECU location....does the lancer 97/pizza pie run on unleaded or leaded gasoline?
Quote from: mykdelarosa on October 29, 2009, 03:05:19 AM
unleaded gas.
