The Ishneakey 2010 Thread
Started by SR71Blackbird, January 01, 2010, 09:02:03 PM
SR71Blackbird
Quote from: chrisboy on June 03, 2010, 05:05:37 PM
@danny... wala naman akong nakikitang water marks. lemme check
Kahit dagta?
Or Love Juice maybe?  :rofl:
Oh Sh!t I'm Late Again!!!
gianGT4
Quote from: rt140se on June 03, 2010, 10:43:36 AM
i think tama lang. nga pala, forced-fed engines tends to heat up more compared to NA. thus, it may really consume water lalo na if pure water lang and no coolant added.
how about your engine? do you use water lang or coolant din?
and do you top up?
Quote from: SR71Blackbird on June 03, 2010, 05:38:13 PM
Kahit dagta?
ilabas ang black light.. :guns:
Quote from: SR71Blackbird on June 03, 2010, 01:03:45 PM
When water inside our Engine and Radiator heats up, the Radiator Valve Cap opens to liberate some (positive) pressure inside the Radiator and the water goes to the Coolant Reservoir. This is the reason why the Coolant Reservoir only needs to be filled up to its water level marker. That air space is important to give way for expansion.
Assuming that the Cooling System  is perfectly sealed, when it cools down, it creates a negative pressure (vacuum) and the water is suppose to be sip back from the Reservoir to the Radiator. If such process doesn't gives you that result,
I believed that somewhere down the line there is a leak or you have a leak in your Radiator.  :sign13:
I'm sorry but 250ml-330ml top-ups on a daily basis is too much for me. I don't think that such engine regardless FI or NA was designed to be that inconvenient. Do you?
Post Merge: June 03, 2010, 01:09:33 PM
Probable leaky Radiator somewhere above. Why don't you do a visual inspection of dried watermarks.
in any case, pag naka luwag na ko.. a corona alloy rad will come to autotech..  :evilgrin2:
Oh shiiett na malagkit na nagkadikit-dikit na kulay violet!
Quote from: gianGT4 on June 03, 2010, 09:02:57 PM
and do you top up?
both my cars runs on coolant + distilled water. no, i never top up... once lang pala. nung pinuno ng tubig nung istupido naming driver yung reservoir ng blue.. ayun, tumapon yung coolant. sayang. :violent1:
Cross020
#1503
Quote from: rt140se on June 04, 2010, 12:24:35 AM
Hehehehe i agree with Jez. Since the radiator replacement nag top up ako twice pa lang. And napalitan sya before the december BRC trackday. I just check the water level sa reservoir every weekend before going to autotech dahil sobrang init ng panahon.
And yeah mula nung nag uulan, ang ganda ng takbo ng auto ko. Parang mas excited pa sya sakin bumiyahe eh. hehehe
Post Merge: June 04, 2010, 02:08:38 AM
@GIan TRD: take a look, baka trip mo. Parang pang USDM eh. Pinakita lang ng barkada ko, ikaw agad naisip ko eh heheeh
http://www.mitsulancerph.net/yabb2/YaBB.pl?num=1275035682
orido130
@all: guys alam ko na deperensya... radiator talaga nagbawas nanaman naglagay ako 1.5li of water kanina umaga..i guess may leak to na di ko nakikita dahil pag tumatakbo lang sya nag leleak..better to change my rad na pag nakaipon, tambak muna ulit si puti sa garahe heheheh.. :)
Quote from: Cross020 on June 04, 2010, 01:56:17 AM
at syempre, access denied ako diba? :rofl:
@ken: not allowed to enter din ako. kelangan pa mag-sign up.  :) bakit ka nakakapasok, member ka ba dun?
copy and paste mo nalang yung pics.  :thumbsup:
Cross020
#1507
Quote from: rt140se on June 04, 2010, 09:11:17 AM
LOL sorry naman.
eto pic. Not too sure if pang 92 nga sya or what:
Pang ganito daw sya eh... pero parang iba. You decide.
The guys is selling it for 7k with tires na daw.
orido130
guys mga magkano kaya ang waterpump ng st? surplus sana or bnew, pa indicate naman price ng dalawa thanks. mukhang waterpump eh may leaking water sa ilalim sa side ng waterpump.
n00n00
told you to check it  :thumbsup:
2-3k for a brand new pump ata.  wag mo pagtipiran ang waterpump  get a brand new one.
orido130
^^thanks noonoo, i called shags na tama ka sa pricing hehehehe go na ako sa bnew para less hassle, and i think baka isabay ko na si radiator para safe ang byahe, eto na daily car ko ulit mas matipid talaga sa gasolina eh yun nga lang di ganun ka comfort. :P
mdc
^^^^ wow!!! i haven't checked this thread in two days and it has already summed up 3-4 new pages! hehehe
anyways, jumping back to the old topic! thanks to all that have tried the shop (uberwerke). let me know if you need anything else.
and i'm always open to comments for improvements!  :cheer:
now back to the topic!!! i'm lost! hehehe!
bosstl
hello po mga boys...
pwede patulong... i need the number of bong (promaster). kung meron din kayo email nya na alam nyong active, pahingi na rin po.
tenchu. mwah mwah. tsup tsup.  :evilgrin2:
>>> http://www.cardomain.com/id/bosstl <<<
say my name...booosss...tiii...eeeelll
nemo
#1513
Bluedevil_ZZ
Quote from: bosstl on June 05, 2010, 01:05:29 AM
yun lang may balak oh! Fresh look for the Toms C3
