dexron 2
Started by ydnar28, March 05, 2010, 08:49:52 PM
ydnar28
mga sir san po b nbibili un dexron. i tried na s mga auto shop d2 s amin puro wla.
sa kasa lang po b nabibili un. tia
Its DEXRON. Dexron II is an old spec of ATF, just use Dexron III.
ydnar28
#2
Quote from: Conan on March 05, 2010, 09:55:42 PM
sir my ride is honda city '97. hindi po ba s mga bagong model un dextron III? is dexron a brand name or a specs.
what would you recomend since my ride is 2nd hand wala po ako manual and one year na po skin to. and i want to change atf n po.
s casa lng po b nabibili un? tia.
Quote from: ydnar28 on March 06, 2010, 12:14:14 AM
DEXRON in a nutshell is a composition requirement for ATFs. usually, the atfs you'll buy will state its dexron class (II or III or whatever). its not a brand. just check the labels on the atfs you'll see in a shelf/store.
a truevalue center is accessible to you, they have quite a lot of atf selections. :thumbsup:
Since your car is a Honda I think you should buy the Honda ATF at the Casa. I remember reading that Hondas are very sensitive to the type of ATF used.
ydnar28
#5
Quote from: rt140se on March 06, 2010, 07:19:47 AM
thanks for the info sir. i just drop by sa ace hardware see diff. brand nga with dexron and mercon requirements. maybe its safe nga siguro as said by sir conan to use a honda atf nlng. kz lately nag- aadd ako ng petron ATF bigay lang ng bayaw ko nagpalit kz xa ng atf sa starex nya.
un sa awa ng diyos lumakas un tagas s transmission ko kya mgchange atf na ako.
Post Merge: March 06, 2010, 10:09:29 PM
Quote from: Conan on March 06, 2010, 10:50:47 AM
thanks sir... siguro nga i used honda ATF nlng para safe. kz cimula nung nag-add ako ng petron lumakas tagas ng trans. ko dati patak patak lang.
how much po kaya ATF sa casa & ilan liters po kya aabutin ng ride ko.
again, the leak won't be solved by atf. have the tranny seals replaced para maayos yan then use the proper atf.
ydnar28
Quote from: speedyfix on March 07, 2010, 10:12:35 AM
thanks sir... nakita ko na po un tagas sa ibabaw ng trans. un papunta sa radiator un my O-ring. DIY ko na lang siguro palit O-ring.
and then ska change ATF n.
