Rack and Pinion Leak! Help
Started by cabron, April 28, 2010, 12:54:15 AM
cabron
What happened: Also had my usual change oil at shell. When the car was lifted up, the mechanic noticed that there was a leak from the power steering fluid. He said that it was coming from the Rack and Pinion.
Question: what to do with this type of problem? where to have it done (affordable price)? and how much?
Help! :(
Usually you can just get an overhauling kit and have the seals replaced. If you're unlucky, you have to replace it.
cabron
thanks for the quick reply sir Brent. How much ang overhaul kit and how much if i have it replaced with a surplus/replacement part?
Lumy2.5V6
Depends on car make and model. Preparing 3,500-4000 may be a good start.
...'scuse me while I kiss the sky!
cabron
3500-4000 for replacement or repair? i have no idea about the prices hehe
Lumy2.5V6
Quote from: cabron on May 07, 2010, 06:06:14 AM
OEM Power Steering Overhaul kit. But that price is generally for Mitsubishi.
steering racks have repair kits but if the shafting is damaged the leak will return din even if you've replaced the seals.
city09
what to do pag shaft ay may tama na sir?!
Lumy2.5V6
Quote from: city09 on May 31, 2010, 06:31:12 PM
Malamang bili ka ng buong assembly rack, pwedeng replacement or surplus up to you sir.
