Starex vibrates while on "D"
Started by accordion, August 04, 2010, 05:17:57 PM
accordion
Good day sir,  ask ko lng un starex ko (1999 model, a/t) pag nka "D" sya then nag trafiic nanginginig sya na parang mamamatay ang makina, so everytime mag traffic or huminto ako nilalagay ko lagi sa "N".  Before kc kahit nka D at tinapakan ko ang preno while on traffic walang vibration na parang mamamatay. ANo ba dapat ipaayos dun or linisin? ok nmn engine supports ko.  thanks all
Baka dirty injectors. Pag D kasi meron na konteng load yung engine and di kaya ng idle rpm mo. Try mo muna fuel treatment with injector cleaner then hataw mo sa nlex baka sakali mag back to normal.
Paul
pag nagva-vibrate na ba do you notice your idle going down? observe mo idle ng engine mo even when in "N". does it fluctuate erratically or does it fluctuate pag nag-engage ang compressor ng AC? maaari din yun ang causes.
accordion
Quote from: Paul on August 05, 2010, 03:43:52 PM
I noticed nagvivibrate sya pag nag engage ang ac comp., ano dapat ipaayos pag ganito prob? thanks.
Paul
Quote from: accordion on August 06, 2010, 05:23:43 PM
pa-check mo na lang sa mechanic. di ako sure kung may idle solenoid ang diesel e. for the meantime try mo pag nagvibrate siya while on "D" shut off mo AC mo. tignan mo kung mawala or mabawasan vibration.
benguet_buynsell
pa check mo injection pump mo. either change or calibration, change your fuel filter also.
accordion
Good day, mga sir slow/hard acceleration starex ko, newly change oil na sya, mobil delvac mx 15-40, ok ang atf, need ko pa dagdagan ng apak un silinyador to pick up on acceleration, napansin ko na eto prior to change oil kla ko magiging ok aftr C/O. un kia pregio ng friend ko pinalinis nya un injection pump and presto gumanda hatak as in bumalik un angas ng engine. Ask ko mga sir if na experience nyo na eto at injection pump cleaning nga ba solusyon, TIA and more power to all. ride is 1999 starex A/T 98,500kms.
re: vibration, napansin ko kht of ang a/c nag vi-vibrate p dn sya, newly change oil & atf n sya. TIA
At 98,500 kms pag di ka pa nagpapalinis ng injection pump and injectors, I suggest you do so. Di naman maintenance free yan.
benguet_buynsell
Quote from: accordion on January 22, 2011, 05:46:14 PM
I had that problem to with my mitsubishi delica 4D56 automatic di makatakbo tapos mausok. I had it calibrated sabay bumili ako ng bagong nozzle tip.
