small amount of oil coming out in my breather..- 2e engine pls help
Started by arduoj, November 05, 2010, 04:04:29 PM
arduoj
pls help..been dealing this for a while..though it doesnt affect the performance of the car..it's just very annoying everytime you open your hood you see small amoutn of oil in you breather.
t2erns
autotechnician /diagnostics / repair 09169784616
ej mobile auto-tech
ericbalajadia
You're right t2erns..
If oil still comes out, check your oil level and make sure it is not overfilled. If the discharge is accompanied by smoke, it could be a start of the condition known as 'blow by' which is an engine mechanical failure that may lead to expensive repairs if not addressed immediately. Consult an experienced mechanic.
0939 334 6424
[email protected]
arduoj
the was just top overhauled about 2 mounths ago..so i think the engine is in good shape..im not really that goo in automotive..may i know where is pcv located in my 2e engine?tnx
t2erns
not familiar with your engine, but pcv general location is; it is plugged in to the valve cover and with the other end of the valve connected by a hose to the intake manifold vacuum
ej mobile auto-tech
ericbalajadia
Quote from: arduoj on November 08, 2010, 11:01:59 AM
Did they check the cylinders and had the rings replaced? If by changing the PCV valve solves the problem, then ok. If not, go back to the top overhauling procedures your mechanic followed.
0939 334 6424
[email protected]
arduoj
already replaced the pcv valve..and it works fine now..thanks again to all you..
Rhay
sir same problem here. how can you replace the pcv valve? thanks.
Quote from: Rhay on November 23, 2010, 11:09:42 AM
sometimes you dont have to change, sometimes they are just clogged. Just remove the valve and spray/soak with carburetor cleaner.
arduoj
mine is really busted , rubber got brittled..so i have no choice but to replace it. Just pull it off and your good.
