intake /exhaust modification...
Started by blacksharkfin, November 19, 2010, 10:58:12 PM
blacksharkfin
     bros, okay din ba e2 kahit sa diesel engines? plano ko gwin sa adventure diesel eh.  :evilgrin2:
thanks!
blacksharkfin
...will it gain hp? or just additional expense lang? as far as i know kc, sa diesel engine oki lang n hot air ung sa combustion chamber? and it has no spark plug. kung CAI and setup, oki lang kaya? now lang kc ko sa diesel engines so im still trying to figure it out..... the stock muffler? i am planning to change it also... thanks!
It will gain hp. Diesel engines and gasoline engines are similar. They are both internal combusĀ­tion engines designed to convert the chemical energy available in fuel into mechanical energy.  Both use and need quality air and both need to get rid of exhaust gas fast.   In the Philippines, diesel performance might not be very popular but very popular in the U.S.    An intake and exhaust mod will do just fine.
blacksharkfin
you'll get some gains but on the non turbo diesels maybe not too much.
niky
Probably not worth spending on. You'd get better results converting to turbo.
If you already have turbo, intercooler, exhaust and alcohol/water injection upgrades are usually worth doing.
