lowering springs/coilovers for corolla bigbody
Started by opinion, April 11, 2011, 04:00:00 PM
opinion
i have a 93 bigbody, any suggestions for inexpensive suspension upgrades for lowered stance, comfort and performance? everything's pretty much stock, using 15 rims. thanks in advance kind sirs
SR71Blackbird
Forget coilover if you mean inexpensive.  ;D
Comfort levels varies from one person to another and somehow inversely proportional with performance. For a compromise setup, my vote goes for Tein S.Tech Lowering Springs. Your choice if you go Soft or Medium.
:sign13:
Oh Sh!t I'm Late Again!!!
czn030
Also, once you replace your stock springs with the lowering ones, better change the struts to a gas type or else bouncy yung ride mo. You will spend around 20k for the set-up.
How much is your budget btw?
bonecrusher
hi, expect to spend if you want comfort and performance. If you compromise, itll be cheaper   :)
Be careful when you consider the sulit coilover sleeves, Ive known of two people who use them and regreted it.
Quote from: bonecrusher on April 17, 2011, 08:21:29 PM
i'd say that you can't have both comfort and performance when you're looking into tweaking your suspension. been there, done that. :sign13:
