help on honda civic 94 overheat
Started by jokerbugoy, April 12, 2011, 12:04:11 PM
jokerbugoy
need help or any advice.. nakapg back read ndn po ako.. pero hoping na may mga new advice or help ako makuha..
my honda civic 94 esi may time na ng ooverheat.. pg nakaka 3-4hrs drive na ako.. dun na ng hihigh temp.. dinala ko sa mekanik sinubukan namin alisin muna un theremostat para malaman namin kung un nga prob.. but then ng overheat padn.. sa tingin nyo po ba cylinder head na prob? always ko nga check water.. bago ako umalis check ko water... lagi un.. kht san ako mg punta check ako ng check ng water.. meron naman water.. last night un pinaka latest na ng high temperature.. advice namn mga sir... tnx! :crybaby2:
need to fix it asap.. going to baguio this holyweek... hay...
Quote from: jokerbugoy on April 12, 2011, 12:04:11 PM
When I used to have a 1993 Civic ESI the cause for rising temperatures was a faulty sending unit that turns on the fan/auxiliary fan.
jokerbugoy
we already checked the fans.. and its all running perfectly..
Quote from: jokerbugoy on April 12, 2011, 08:30:11 PM
Are both fans running when it overheats?
tip_tipid
so there is no thermostat now in your car's cooling loop. perhaps you need to replace the water pump. if the car has been running without coolant for a vary long time, the water pump vanes disintegrates due to corrosion.
jokerbugoy
#5
Quote from: Conan® on April 13, 2011, 09:01:58 AM
yes both fans is running when it overheats.. the temp gauge is playing.. sometime normal after few kilomotere it will go high again...
Post Merge: April 13, 2011, 04:33:33 PM
Quote from: tip_tipid on April 13, 2011, 02:13:36 PM
i have coolant on the radiator.. the mechanic told me that if still overheating maybe the head gasket is the problem.. what you think guys?
Post Merge: April 13, 2011, 04:51:40 PM
one more thing na napansin ko.. nun naka idle lang car.. n umikot ako sa car to check for leaks..
napansin ko may water na lumalabas.. ano po kaya un?
tip_tipid
what type of coolant have you been using so far?
czn030
Quote from: jokerbugoy on April 13, 2011, 04:31:12 PM
Saang banda lumalabas yung tubig? Dapat kung ganon nagbabawas ng tubig yung radiator mo. May naririnig ka bang parang kuliglig sound mula sa engine bay? Nagpaoverhaul ka na ba ng radiator? Try mo bago istart sa morning, alisin yung rad cap at check mo kung yung tubig ay dadaloy once nirev mo yung engine. Pag hindi na, better check the water pump.
jokerbugoy
#8
Quote from: czn030 on April 15, 2011, 10:16:02 AM
sir sa muffler lumalabas un water.. parang ng sprinkle cya..
Post Merge: April 16, 2011, 01:33:52 PM
Quote from: tip_tipid on April 14, 2011, 02:24:03 AM
is used top1 coolant..
Post Merge: April 16, 2011, 01:36:21 PM
isa pa sa na observ ko.. when i started the car.. and open the hood the radiator fan not working.. then may times working naman.. is it normal at first hindi muna ba andar ang fan?
1st time po kasi mg ka car.. kaya no knowledge pa sa parts.. help guys tnx.. :newbie:
tip_tipid
Quote from: jokerbugoy on April 16, 2011, 01:33:03 PM
normal lang na may lumalabas na tubig sa muffler kung bagong start engine. ito ay gawa ng condensation habang lumalamig exhaust system, lalo na kung overnight.
is this glycol based, safe for aluminum alloy?
normal lang na di umandar ang fan/blower upon starting. aandar lang siya kapag na-reach ang slightly above operating temperature ng engine, tapos hihinto kapag napalamig na niya sa tamang temperature ang engine.
SuPeR_MaN
sir kumusta auto mo? i had a big headache when it comes to overheating so I've learned a lot of things when I was in your situation. open mo ang radiator cap, then rev the engine. pag lumabas ang tubig from the radiator, your cylinder head gasket is for replacement. advice pa sa akin ng mechanic ko not to use an engine coolant dahil tumitigas daw ito sa loob ng radiator, water will do.
Quote from: SuPeR_MaN on April 29, 2011, 03:09:37 PM
If you don't use coolant your radiator will rust out and develop holes.
SuPeR_MaN
^ ganun ba yun? okay salamat sa advice sir!
Old school misinformed mechanic's advice is not to use coolant. You should use coolant and change it at proper intervals.
your sending unit to the gauge might be shorted also causing the gauge to read incorrectly and you to think you're overheating when you're not.
