The Ishneakey 2013 Thread!
Started by rt140se, January 01, 2013, 12:50:54 AM
SR71Blackbird
#1
 :rock:  :rock:  :rock:
Another year of renewals.
:occasion14:
Oh Sh!t I'm Late Again!!!
ilovehumps
私の愛はこぶ トヨタカローラAE101用
SR71Blackbird
#3
@ilovehumps
Hindi ako sigurado kung nasilip mo na oto ni rubpas. Pero iyung counterpart ng RSM (forgot the brand) na galing Japan ay nakakuha din si oly101. Kung may makukuha pa ay pinarereserba ko na... para sa iyo.  8)
Not unless, wala ka ng SLC ngayun.
ilovehumps
ah yes, "ultra".
thanks! i still need it, inaccurate pa rin speedo ko, its a good tool to display the correct reading & feed the essential data to the ecu for further manipultation hahaha
sige ill take it! thanks!
chrisboy
danny... pag bibitawan mo na yung rsm pag dating ng gauge 2 mo let me know baka may budget ako :)
I need donor tires. Hu hu hu...
:crybaby2:
chrisboy
hhhmm.... toying with the idea of installing adjustable cam gear. i dont think i'll be modding much though. for one to be able to really use this upgrade, what else needs to be done?
note... i am not sr71blackbird :) so tipid meals upgrade :)
Chef, if the future of the corolla is really not that clear, i suggest you hold back with the idea.
Pero if you still decide to go with it, just rember the golden rule of tuning:
"With any engine upgrade installed comes the need to compensate it with the right air/fuel ratio for it to be effective..."
Safc II will do.
chrisboy
Jez... Yup yup need for engine management. Hhhhhmmmmm.... But can the camgear be installed and put in stock setting until such time that engine management is available? Or better do all at one time?
SR71Blackbird
#10
Parang uulan ng Adjustable Cam Gear... hmmm.
Parang it offers good while supply last.
:rofl:
@chrisboy
Kung Exhaust Side lang ang lalagyan ay puwede naman i-set ng mga 2 degrees (retard ata) para maaga-aga ang powerband. Kung zero (eye-candy) setting, at least you shave a little weight from the engine.  ;D
chrisboy
Quote from: SR71Blackbird on January 06, 2013, 09:12:23 PM
:rofl:
@chrisboy
Yup eye candy muna siya hehehe
ilovehumps
update:
alignment fixed! superb handling!
camber: -1.5 all corners
alignment: 0.2 toe out front / 0.2 toe in rear
SR71Blackbird
Given the stock Cams, the curve is inclined to rise after 8700RPM.  ::)
Not sure if forging (ConRods & Piston) plus the Valve Springs (of course) would be a good choice this year. The objective is to safely sustain above 9000RPM while tapping that powerband.
Eh di Tenor na siya.
:rofl:
