205 on a 15"?
Started by luwe, April 19, 2003, 04:34:33 PM
luwe
Yung gulong ko kasi ngayon Potenza GIII na 195/55/R15.   Okay naman siya malakas yung grip lalo na kasi underpowered kotse ko.  Pero iniisip ko lang, meron bang 205/55/R15?  At kung meron man pwede ba sa mags ko yun?
Protegetech http://www.protegetech.org/
Ford Club Philippines http://www.fordclubph.com/
IMm29
Quote from: luwe on April 19, 2003, 04:34:33 PM
what car?  stock ba yung wheels mo?  me wheel size na 205/55R15.  palagay ko, kaya naman ang 205/55R15.  the next question would be kung ok ba yung tindig, kung hindi ba naman sasayad sa fenders, at kung hindi ba mahihirapan yung suspension mo dahil sa lapad nung 205.
The Devil Drives Prado
KeWlRyDs
there is a 205/55-15 tire size available and chances are it will fit your current set of wheels. but if you say your car is underpowered, using wider tires would  aggrivate the situation since wider tires means more rolling resistance.
luwe
yung roll nga yung gusto kong tanggalin... ford lynx yung kotse.  nasabi kong underpowered kasi yung suspension niya kayang kaya kahit mas malakas pa yung makina
KeWlRyDs
can you give your definition of what roll is? the roll resistance i'm pertaining to is the force needed to make the tire rotate. if your thinking of roll in terms of body roll in a corner, a wider tire doesn't really cure it. tweeking your suspension is the answer. using stiffer springs (lower) and matching dampers reduces the amount body roll the car during cornering. another part that you can upgrade or add is an anti-roll bar (also known as stabilizer bar).
R600
i don't think wider tires would help much with the body roll of a vehicle but it will improve traction.
luwe
ibang roll pala sinasabi mo hahahaha.  mas madalas kasing gamitin yung salitang roll para sa body roll.
pero mukhang oo nga mas mahirap umikot yung gulong.  pero kung mag 16" or 17" naman ako ganun din diba hihirap din yung pagikot ng gulong.
fatbastard555
dude get bigger diameter rims ('usual' 15-inchers are 6.5" across) and fit 195/55/15 tires on them. this is what some people from Yoko told me. :)
EK3 Ferio
i'm using 205/45/r16 swak sya sa EK ko.
if there are any wheels that come out in 205/55/r15 or even 205/50/r15 could you guys point out any models you know of?
NB_bluestar
Im currently using 205/55/R15s Potenza G3. No problem whatsoever. i think mas comfortable ng konti yuun ride compared to 195/55/15s. Medyo mahirap lang nga maghanap ng ganitong size kasi alanganin sya. Usually kasi kapag 15's, 195/55/15s are used more often. Aside from that, it's a bit expensive also...cost around 3K each. Acutally, you won't notice the difference in the size compared to 195/55 - 205/55 (additional 10mm) not unless you like  staring at your tires palagi;D
R600
maybe you'll notice it during high speed cornering...then again, the difference is rather small...
conrad
bluestar
are you using stock mags? what car?
thanks!!
NB_bluestar
conrad
im using aftermarket mags 15's size 6.5jj for my nissan exalta. :)
luwe
Ouch!  500 pesos difference per tire!  2,500 bili ko sa GIIIs ko e.  Hmm siguro nga 195/55 na lang talaga ako.
IMm29
NB,
i think the reason why the car rides better on 205s than on 195s is perhaps because the former has slightly more sidewall height.
luwe,
kasya yung 205s sa wheels mo.  mas mahal nga lang talaga sila sa 195s.
