Infinity Reference Amplifier
Started by MrCurious, June 01, 2003, 02:12:59 PM
MrCurious
Has anyone able to audition one of this amp? this is the infinity amp available at Autosport in Mega mall. This is roughly 22inches long? Pls advice if this is a good amp. It has flexible chanels 2/4/5/6
A+ Audio
I think it should be ok just check the THD(%) hwag sana lalaki sa 0.005 ang THD as a general guide line and sana at least 2ohm stable at stereo. Wattage does not matter but should match your requirement. :)
Billabong
#2
sir vic, maybe you mean to say .05 THD.
nabasa ko na basta less than 0.1% ang THD acceptable pa. there's no audible distortion.
A+ Audio
what i meant was 0.005/100 = 0.5%
MrCurious
Appreciate your inputs guys.. Any other who are able to use or audition this amp? It looks very worth it for the value of the amp.. I believe it has also built-in xover..
Billabong
Quote from: A+ Audio on June 01, 2003, 11:52:43 PM
sir vic, .005/100 = .00005.
maybe you mean to say .005x100=0.5%
peace! :)
